Power Steering
integrator
Power Steering
Post by integrator »
I've had no power steering for 2 weeks now and I want it back.
I don't know where I can get the parts (haven't tried the dealer yet but I'm trying to avoid them.) I have some rusty lines and this is causing the problem. The fittings are also very rusty going to the rack.
Has anyone else encountered this problem? What solution did you have. I don't necessarily wan to buy a new rack but I think if I start trying to get those fittings loose I will nothing left to attach new fittings to. I've been searching on this site and haven't come up with a solution that I wouldn't mind paying for (quicker rack for non-outrageous price would be nice. I would like to replace the lines that are rusty. Is this a large job? Does anyone have the FSM procedure?
Maybe these are too many questions at once. Thanks in advance for your help.
douglas vincent
Post by douglas vincent »
I actually have no power steering either, but not just none, but NONE because I am not spinning the power steering pulley at all. It is totally livable this way, just not preferable. I would attempt to bypass your power steering pulley by getting another belt and try that until you can actually fix all your messed up crap. The only time I miss the PS is when I am parking. The loss of it actaully makes the car handle better in my hands.
integrator
Do you have a part number for the belt you are using I was considering this route too actually. Don't wanna destroy the pump too. I will try some belts this weekend.
I guess if I take a piece of string and wrap it around the pulley's I can get an approx. size.
douglas vincent
my ps pump is bypassed because of my SC setup. But get a Dayco Polycog belt 5050.... They are great belts.
integrator
Thanks that's perfect. I'll pick one up tomorrow.
Post by SubaruNation »
ok so is too much Power Steering fluid bad?
Yes. Subaru specifies a limit to how much to put in for a reason, of course. As the fluid heats up it needs room to expand. If you don't have enough space in the system because you've overfilled it, it'll force its way past seals in other places. If you're especially unlucky, some will spray onto a hot exhaust component, where it'll catch fire.
If you've overfilled your power steering system, just get a $1.99 turkey baster and remove the excess fluid.
shit
SubaruNation - What's the big deal? Just take some fluid out.
But anyway, back on topic -- integrator, what about just getting a junkyard rack with its lines? Swapping the steering rack isn't that big a job, and I'd imagine you could get the rack for less than a hundred bucks.
It's just going to overflow. You don't have to worry about the seals because the extra fluid isn't going to change the output pressure of the pump.
Oh, is the cap not sealed?
Sort of, but not really well. There's always a little bit of ooze around my power steering cap.
Arctic Assassian
Post by Arctic Assassian »
this thread is OLD!
Kickin' it old-school.
Arctic Assassian wrote:this thread is OLD!
WOW.
really?
i posted in here b/c i wanted to save leg-central space on the net,
and yeah i took a surgical surenge (medical family, i know) and some fish tank clear rubber tubing yesterday and removed a bunch, leg777 you were right it just flooded over the top from under the cap. i didn't burst anything.
kinda cool, it was like i was taking blood out of my car :-D
b/c my ps fluid is red.
thanks guys :D
