dumb question about air filters
mark-b
Post by mark-b »
I looked around my air filter housing (rectangle in shape) and a bit unsure how you open it up to throw in a new filter. As you can tell I'm only onto my first legacy. Mark
stant093
Voluntarily Dismissed
Post by stant093 »
there is four clips that you have to flip open, then it should open up with no ease..just take another good look...if its not 4 clips, its 4 i believe 10mm bolts...just as easy as the clips but take a few seconds longer to undo...but beware, after unscrewing them, sometimes the nut on the under side will fall off never to be seen again, its a good practice to place a finger under the bolt when taking them out...
mark-b
Post by mark-b »
Hi Stant093,
Thanks for the tip. I dont have clips so I will have another close look for the bolts. On the 4 corners on top there are round bolt heads that almost look like alan-key holes in the center. I dont know if these are the ones you are talking about but I will go exploring. Thank you.
Mark
Post by entirelyturbo »
Yeah, we don't have clips :D . I hate clips...
They are screw-bolts (whatever you call em) that are 10mm or Philips screwdriver...
And I personally have never had a bolt fall out, I think they're held in place...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
ciper
Post by ciper »
Yeah, the screws wont fall out. I needed a couple from the junk yard (someone stripped the phillips head out of mine) and it was easier just to replace the air box top then to remove the screws.
