Rear pads?
Rear pads?
Post by BAC5.2 »
How different are WRX rear pads and Leg Turbo rear pads?
I don't have any spare rear T-Leg pads, so I can't compare right now, but I'm curious.
I got a set of Axxis Ultimates for free from a buddy of mine and my rears are crying, so I was hoping I could use the WRX pads.
they are different, and won't work.
The tabs are what is different. The WRX pads use a single tab on the pad that slides between two brackets/tabs on the caliper bracket.
The turbo legacy pads or n/a legacy pads for that matter have two tabs on the pads and the caliper bracket has one tab/bracket.
Post by BAC5.2 »
Gotcha. Thanks Josh!
Guess the rears will have to cry for a while.
On the plus side (if you want to call it that), the NAPA "Premium" pads up front lasted just under 7,000 miles before wearing to the screamers. Crazy, huh?
Jeeze....that's pretty bad.....you tracking the car? Or that under "normal" driving?
Post by BAC5.2 »
Well, not exactly tracking, but I do put the car through it's paces. It's been more than once that I've ended a back road romp with smoking brakes and less than cool rotors. I wish I had an IR temp gun, as I am sure the rotors were up close to 700 degrees.
scottzg
Post by scottzg »
That's incredible. My "premium" pads went 16k, and they got cooked at least weekly. I guess i have less cooking power...
Rotors are so glazed you might expect to find them in a pastry shop too...
Post by BAC5.2 »
And my brake fluid looked like this:
THAWA
Post by THAWA »
I'll give you 10 bucks if you drink that.
QuickDrive
Lurker-King
Post by QuickDrive »
I see Thawa's 10 and raise it to 20$
R I P-------- 91 Turbo 4EAT --------R I P
I'll add 5 more if you drink it through one of your stock brake hoses, sucking on the banjo end!
