Will '91 2wd N/A GR-2's fit my '91 SS??? What is different? They seem to be the same length. I see the mount is in a different place. Will it change my rear alignment?
Thanks!
Whats the diff between 2wd and 4wd rear struts?
please try and utilize the search feature
this thread will have the info you need.
http://www.bbs.legacycentral.org/viewto ... sc&start=0
Thanks Josh, I did search and did find that thread, although interesting, I didn't see where it answered my question but I might have missed it.
I noticed there was a reference to all PN's being superseded by one number.
When I compared the struts I noticed the spacing of the lower mounting bolts was about 1/4 farther from the strut body than the stock ones. I guess I'm just wonderig if these will fit without screwing up my rear alignment. The overall length and spring perches appeared to be the same.
Sorry for the elementary question and for the redundance but I really appreciate any help you can provide.
greg donovan
Oops....my bad....I think that thread only talks about AWD.
The FWD struts are longer and the perch is different as well.
They'll bolt up, but it'll jack the ass end up. You'll also need the FWD rear springs as the AWD springs won't work. I found that out when I put the rear FWD springs on the donor wagon so it could be rolled away.
