It should be easy, Mike. The "FWD fuse holder" is actually just a switch to ground. And you know what? So's the handbrake switch!
Try this and tell us how it goes:
Get a couple of diodes. Schottky-junction ones would be ideal but I'd expect any kind would do.
Remove the center console and find the little quick-disconnect-type connector at the rear of the parking brake switch. It should have a blue-with-red-stripe wire attached to it.
Disconnect that little connector. Connect both diodes' anodes to the switch in its place.
Connect the blue-with-red-stripe wire to the cathode of one diode. Connect a long wire to the cathode of the other diode, and splice that into the black-with-red-stripe wire going to the FWD fuse holder.
You should be able to do all of this without actually cutting any wires if you just use quick disconnect connectors everywhere... a male quick disconnect should even be able to go into the FWD fuse holder.
If it works right, you should be able to just pull on the parking brake and see the FWD light come on in the dash.
Let us know if it works.
