Soobie bolt pattern
mrkingers
Soobie bolt pattern
Post by mrkingers »
My 92 has black steel rims on it, 5 bolt...
I assume it's a 100mm / 4 inch bolt pattern.
What other (If any) make of car rims would fit this bolt pattern?
1992 Legacy L AWD
2.2L MPFI 16V
-K-
Post by -K- »
None, if you want to keep the correct offset, that I know of.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
Right, the only OEM rims that properly fit Subarus are from Subaru. No other manufacturer uses a high enough offset.
Some people do use 5x100 Volkswagen steel wheels for their snow tires on Subarus. The offset is about 20mm lower at 35mm rather than 55mm. If the snow tires are narrow, and you're really lucky, then you might not get too much rubbing. It'll still throw the whole system a little out of whack, though.
stant093
Voluntarily Dismissed
Post by stant093 »
i bought a impreza a little while ago, that has oldsmobile rims and tires on it...they seem to fit perfectly, and the kid i bought the car from had them on for almost a year or so......
