1986 GL-10 5sp... should I go for it?
Fugazi
Post by Fugazi »
Alright, so I have a chance to get an 86 GL10 turbo 5sp with all the extras for only $1000! How are these bad boys as far as reliability? I've got two years of school left before the steady paycheck, so I really need to know if theres anything to look out for.
From what he says it really checks out mechanically as far as no leaks or oil burning
1993 Legacy L AWD, 5 speed, 201k miles
KYB GR-2, K&N, snorkusectomy
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
No problem. They're like bricks. My brother had one with 2XX,XXX miles, eventually had it rebuilt but it was a tank. He took out 120 feet of fence with that puppy with only broken suspension components on 1 corner and a couple dents.
[edit] his wasnt a turbo, but he used to rave about how reliable the turbo model's engines were, and how badly he wanted one[/edit]
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Post by entirelyturbo »
Waaah! I want it! Especially if it's a wagon! :evil:
There are two major things to check for on EA82T's: 1) oil leaks and 2) blown headgaskets or cracked heads.
1) It's going to leak oil somewhere, if he says it has NO oil leaks, he's lying. If the valves tap, the oil pump needs resealing, I can help out with that.
2) EA82T's have rather insufficient cooling, so if it has ever overheated (can happen from something as simple as a bad T-stat), the headgaskets and possibly the heads are in question. If you've the chance and ability, wouldn't hurt to do a compression test on it.
Also check for rust. 80's Soobs love to rust.
Good luck!
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Fugazi
Post by Fugazi »
Sweet! I'm having a friend drive up to check it out this weekend, if it looks good, shes mine. I'll post an update if I get her. This has been my dream car since high school, silly I know, but even more so since its a stick.
Tleg93
Post by Tleg93 »
I liked the gl-10's. I'd go for it. I bought my '91 for only 1k too but it had/has some issues.
--Scott--
1991 - Rio Red SS
magicmike
Post by magicmike »
I could not give away my 87GL, I ended up having to pay 25 dollars to have a yard come pick it up.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
