Gas Guage prob
Flip_x
Gas Guage prob
Post by Flip_x »
how do we fix the gas guage mine is stuck in the middle.
ive searched all over this place and all i see is something about the light or the guage not working.
but i want to know how to fix it. thx :D
1990 Legacy Sedan LS AWD 5-MT 162k miles Slate Metallic (Sold to Brother)
1992 Legacy SS AWD 5-MT 180k miles Mica Black
dzx
Post by dzx »
I had that problem. I thought i was getting the best gas mileage ever when traveling through western nebraska. Then i decided to stop and get gas just because the next gas station was 30 miles. Turned out the tank was empty. It took a couple tanks of gas to start working correctly again.
///M
'93 Legacy SS - part out
Flip_x
Post by Flip_x »
well its a diffrent legacy and i think its been broken for a awhile
Tleg93
Post by Tleg93 »
I believe there's a send and recieve unit located at the tank and under the hood. It probably needs looked at, fun fun.
--Scott--
1991 - Rio Red SS
THAWA
Post by THAWA »
how are you liking it?
Flip_x
Post by Flip_x »
how am i liking what? sorry
THAWA
Post by THAWA »
the car
there are two sending units in the AWD gas tank. What I'd suggest doing is pulling the plug under the seat and then turn on the ignition. See if the gauge moves at all. You could try playing with sending 12v to the gauge and see if the needle moves.
If it does, the problem is probably with the sending units in the tank. They can get corroded up. If you pull the pump & jet pump out, and sand the contacts on the little slider, that should help, assuming they're not worn/oxidized too much.
0perose
Post by 0perose »
I'm having the exact same problem. anyone know if Josh's advice fixed this guy's problem?
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
