Modding my 92 legacy sedan
92BlackBeauty
Post by 92BlackBeauty »
im looking for a good ,cost effective mod to wake up my legacy.
1992 ej22t with stock transmission, k&n intake, and magnaflow 2.25" exhaust with one cat removed.
It has the stock turbo on it, is there anyw ay to make more boost off of the stock turbo?
Also, my car tops out at 180 km/h there must be somethign wrong there??
Any suggestions would be much appreciated.
92 SS--up and running finally!!
(edited for Jason Grahns pleasure)
azn2nr
Post by azn2nr »
more boost intercooler new turbo and bigger exhaust. but in the end none of thoes are cheap.
what do you need to go fastar than 180 for
-jason
J-MoNeY
Re: Modding my 92 legacy sedan
Post by J-MoNeY »
92BlackBeauty wrote:im looking for a good ,cost effective mod to wake up my legacy.
FCD and MBC. IC if your lucky. 8)
98 LGT
92BlackBeauty
well actually i have a stock intercooler on it...im not sure if it is air to air or other.
And by installing an FCD how much power could i expect?
And also the manual boost controller...how high of a PSI can i safely run?
does anyone know who makes a cold air for a 92 legacy?
J-MoNeY
Post by J-MoNeY »
92BlackBeauty wrote:well actually i have a stock intercooler on it...im not sure if it is air to air or other.
You must not be in the US or Canadia. The FCD will let you run past stock fuel cut off at like 12-13psi. 12psi is about the limit you want to run. I think the VF-11's effecnentcy range is about 12psi as I recall. If I were you. Just get a bigger turbo.
98 LGT
simonasaur
Post by simonasaur »
My oppinion is to free up the breathing to make what you already have more efficient. you can use wrx piping; up pipe, down pipe, the only mod would be to lengthen the exhaust by about 2in, and get new hangers but thaats only like 50 bucks at a exhaust shop. this allows your turbo to be more efficient, its not cheap but the gains are substansal.
looking for a 93-01 impreza shell!!! pm me
J-MoNeY
Post by J-MoNeY »
simonasaur wrote:My oppinion is to free up the breathing to make what you already have more efficient. you can use wrx piping; up pipe, down pipe, the only mod would be to lengthen the exhaust by about 2in, and get new hangers but thaats only like 50 bucks at a exhaust shop. this allows your turbo to be more efficient, its not cheap but the gains are substansal.
Don't use the WRX up-pipe. The WRX one has a cat in in, where our Legacy ones do not. Other then that, you have the idea.
98 LGT
azn2nr
Post by azn2nr »
get a ssautochorme tbe. its freaking asome
i just bought one and its the strightest tbe ive ever seen. only 2 bends in the whole thing and their not even bends more like slight diversions
-jason
Yeah, even N/A US cars go faster than 180 km/hr (much). You must have the same speed limiter as the Japanese market cars.
92BlackBeauty
No acutally I am in Canada, and my car still only runs 180km/h.
If it turns out that it is an import from japan, which i highly doubt(it's left hand drive and has american specs) how can i get rid of the limiter?
So you all seem to be saying that an FCD and the manual boost controller will not be much of a noticeable gain?
And also, just how much of a gain will i receive from running wrx piping all around?
J-MoNeY
Post by J-MoNeY »
92BlackBeauty wrote:No acutally I am in Canada, and my car still only runs 180km/h.
If your in Canada, then how do you have a stock intercooler?
Toying with boost is up to you. Set it at whatever you want and test the waters on what feels the best. As for the piping on the exhaust. DO NOT GET THE WRX UP-PIPE, it's way more restrictive then ours. Get a 3in downpipe and 3in piping to the muffler. You'll see a little improvement there.
98 LGT
Post by BAC5.2 »
There is PLENTY of information on here to search for.
It all boils down to how fast can you AFFORD to be. That's where I'm at now. To get any noticeably faster, It's gonna cost me a full testicle in power mods, and supporting mods.
If you have an EJ22T, then there was never a stock intercooler.
