Subaru engines are tuff !!
morgie
Post by morgie »
Yup, despite -3L of prestone and -2.5L of oil, the engine still runs great ! hahaa (overheat a little bit but runs good :) )
Had a huge prestone leak caused by the Turbo prestone tank bottom plug broken, and have a _quite huge_ oil leak in the water pump area (wich drains 2.5l of oil / month) ... and had to get to work and back home for 3 days on those conditions ... (work + school = no time to work on the car).. but the car supported those conditions quite well.
Fixed the tank today, and put a complete 3l of prestone back into the engine :shock: ... now i have to do something with that oil leak / drain :)
morgie
'98 4Runner V6 Manual 4x4.
ciper
Post by ciper »
Dont be mean to your car!
morgie
Post by morgie »
she's mean with me, so i give it back to her .. :twisted: :wink:
morgie
ciper
Post by ciper »
Kinky :oops:
LOL :lol:
paf
Post by paf »
thats pretty much how I run mine, it leaks prestone all the time, when I giv'r it sprays prstone on my windshield, Tried to fix it with jb weld, it keeps going through, I have a spare rad but its for a manual...
1990 FWD Legacy Wagon Base
ciper
Post by ciper »
Why not just get an external cooler and put the manual transmission radiator in?
Post by entirelyturbo »
I agree. Ciper, wouldn't that probably provide better cooling for his tranny anyway?
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
I think it would. The stock ATF "cooler" is really a heat exchanger between the engine coolant and the automatic transmission fluid, isn't it?
ciper
Post by ciper »
Yeah, I think the stock cooler is great though. The coolant in your radiator is probably going to be between 100 and 170 degress under normal weather. The operating temperature of the ATF should be just higher than that.
Golden Oldie
They really are bullet proof :D
Post by Golden Oldie »
Just driven 140 miles with leaking gaskets (you name them they were leaking oil) and 80 of those miles were on three cylinders as have misfire :shock:
It's at the rally specialists http://www.townendgarage.co.ukalongside Colin McRae's ex-WRC 22B getting some much deserved (if not slightly overdue) TLC ;)
1991 Subaru Legacy 1.8GL 5MT AWD Sedan...in Gold :D 118,881 miles and counting...
[color=red]Visit my website - [/color][url=http://www.legacyregister.co.uk]www.legacyregister.co.uk[/url]
