Newbie with an engine install problem
I purchased a new engine for my legacy and I can't seem to get it to line up properly. It was together for the most part but would not lide in that extra inch or so. I was reading some of the other posts regarding engine installation and they were very helpfull but no matter what I do I can't get it to go all the way.
The vehicle is an automatic, I did take the torque converter off the old engine and swap it over to the new. Both were auto engines with the flex plate.
I was thinking about pulling the transmision out, putting the engine on it and then re-installing it. Would this be easier in the long run? I still have my power steering and A/C hooked up in the engine bay but they both work so I couldn't see removing them.
This is a great site you have here. I found it while doing a google search fo info on my vehicle.
You have to make sure the torque converter is reinstalled all the way into the transmission. It's a pain in the butt to do. Just keep rotating and pushing it back into the trans. It should line right up to the edge of the tranny when it's fully installed. Least, that's what it sounds like the problem is.
Holy crap that was a fast reply.
I jacked the transmission up so that the motor mount bolts would't hit , was I right by doing so? When you say rotate do you mean "stick a socket on the crank nut and keep turning?" If so does it matter which way I turn it?
I also learned the hardway that you have to take the radiator out when removing a subaru engine.
Yes, turn the engine a little so the splines will line up. Play with the alignment a little with the jack and engine lift also. Sometimes it helps to pull the engine back off completely and then try again rather than fighting it. When it's right it pretty much just slides right on.
Hey, STOP I had the same problem putting my engine in. When you pulled the TC off you probably pulled the pump shaft out a little also. Either you didn't mention it or you didn't realize it. Read this
http://bbs.legacycentral.org/viewtopic. ... highlight=
there are 2 links which show the little clip that I'm refering to. Read that whole post and you will figure it out
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
My Dumb ass pulled the saft a little bit out because it was already a slight bit out when I got the old engine off. So you think I should back the engine off and see if it is the pump shaft.
I don't think I understand the clip you are refering to. Do I just give the shaft a few spins and it should just "click." I'm going to go try it now and see what progress I make. I will check back in a few minutes.
it will not go in by just turning it trust me! I messed with this for days literally. Pull the engine and pull the TC off and pull the shaft out and make sure you find the clip, its in the links to the FSM's. Assemble the pump shaft to the TC with the clip and then slide the shaft and TC back into the tranny as one unit and do the spinning thing so it all lines up. trust me on this one
http://www.graphics.cornell.edu/~v/pics.cgi/tc_1.jpg
The clip is on the outer shaft numbered as #10
the clip is #8 on that page
pull #10 right out of the tranny and use clip #8 to clip it to the TC then slide both right back in as a whle like I said above
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
You mean I have to unbolt the TC from the flex plate? If I do that then how do I get it back together once the engine and tranny are mated?
I just went back outside and I see the clip you are refering to in the TC...but how do I get it out? It looks like a ring toward the back of the converter. From what I saw there was no access to the other end of the TC.
Do I hammer the TC onto the shaft? Wil this mess up the pump in the tranny?
Ohhhhhh, yeah you messed that up pretty good lol. you need to unbolt the TC from the flex plate when you pull the engine, so if you are trying to put it back in while the TC is already attached to the engine your never going to be able to rotate it enough to line all the splines up. ok let me tell you what to do here.
1. remove the TC from the flex plate on the motor.
2. remove the pump shaft from the tranny.
3. attach the clip to the pump shaft (it only fits on the end that goes toward the TC.
4. then stick the pump shaft with attached clip into the TC until it clicks. it will be very subtle. give it a slight tug just to make sure it is clipped well.
5. now you will have the TC with the pump shaft attached to it. slide everything carefully back into the trans rotating the whole thing slightly until it clicks all the way in.
6. now put the engine in and attach the flex plate to the TC either from the gap at the bottom behind the oil pan or the cover in the top of the tranny.
mods should move this to the drivetrain section
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Yes that's what I was talking about. I had figured you unbolted the TC from the flexplate
. I was talking about doing #5 of what mike explained.
How do I get the clip out? If you look in the TC whole you will see a solid ring towards the back. It is not a snap ring or anything of the sort. If I slide the shaft into the TC it stops at the ring. I am ssuming it is supposed to because if it went any further it would slide past the teeth. As it is now the teeth in there line up prefectly. MAybe you guys have this confused with something else. If I take the TC off the FP there is still no way to the TC apart so I can retrieve that ring/clip..or is there???
Just tell me how to get it out and I will handle the rest. I checked it real well and it appears to be a solid ring. Not like a snap ring or C-clip. It is waaaayyy bacj there towards the front of the TC.
Thanks again for your help.
- Title Whore
I know when I was installing my 2nd AT, we had to crank the pulley in order to turn the FP enough to get at the bolts. We used sockets and went thru the viewing hole in the trans.. it's time consuming, but at least you get it right, and don't have to deal with a bunch of other honkey..
Good Luck!
Good Luck!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
- quasi-mod-o
You can do this one of two ways.
1. You can remove the TC from the engine and put it on the tranny as mentioned and then tighten the plate from the front through the hole on the bell housing of the motor.
OR
2. You can look into the face of the tranny and find the alignment points. There are two slots on it that correspond to two slots on the TC. Once you have found the orientation of the tranny, mark the outside of the TC and rotate the crank until they line up. Make sure the tranny is in neutral and it goes together easier.
Lastly, check your tranny seal before you go any further. We borked one up pretty badly recently trying to force a misaligned TC in there. If you have crunched it, replace the seal before you go any further...
OR
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
magicmike wrote:it will not go in by just turning it trust me! I messed with this for days literally. Pull the engine and pull the TC off and pull the shaft out and make sure you find the clip, its in the links to the FSM's. Assemble the pump shaft to the TC with the clip and then slide the shaft and TC back into the tranny as one unit and do the spinning thing so it all lines up. trust me on this one
Hey I've got a similar issue at the moment. I would like to see the images but the links don't work. Are they posted any where else? Pretty much I can't get the TC lined up so that it'll push back. PITA that thing LOL.
1.) '02 WRX-2482cc-TD06H-20G-FMIC (just sold)
2.) '90 Legacy-2.5 turbo, VF39, Haltech E8 in-hand - waiting for the 5mt swap
i've been doing auto repair full time for about 12 years----i've learned a lot during that time and still continue to learn. it's been my experience that if you try to mate the engine and trans without the torque conv all the way back, you'll break the drive ears off the a/t pump. put the t/c all the way into the trans first(usually it'clunk 2-3 times as you spin it-----you shouldn't be able to get your fingers behind it---then it's all the way in) then mate engine to trans. i've seen another tech break the a/t pump trying to force them together.clean corrosion from dowels first and as previously stated, if its right, it'll fall together gracefully.
