AWIC tubing?
LaureltheQueen
- Spelling Nazi
AWIC tubing?
For the JDM/ADM awic stock on the leggies...
Does anybody sell this?
Not the stock air tubing, as i believe the turbo's different, but stuff made to "plug and play" on our setup?
If nobody has done this, who would be interested in me having a couple extra tubes bent and putting together kits for the air side of things?
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
92 Le-Turbo-SS
LaureltheQueen
- Spelling Nazi
I would just use a straight pipe with the BPV outlet and a 90 degree silicone reducer to the turbo outlet. Like this http://cgi.ebay.com/ebaymotors/ws/eBayI ... 82666&rd=1
Try to make the pipe the same size as the inlet on the IC and I'm just guessing on the size of the ebay hose. When you change to a better turbo all you should have to do is change the 90 degree elbow for the size and angle of the new turbo.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
93 Sport Sedan, 5mt
LaureltheQueen
- Spelling Nazi
tris91ricer
- Title Whore
LaureltheQueen
- Spelling Nazi
Is the 2nd one heater / rad hose? I was thinking about using a setup exactly like that (obviously with a BPV fitting), but figured silicon couplers would be a better choice.
Edit: Until I saw Canadian prices for them... I guess heater hose will have to do me until the fall, when I can afford to find some cheaper ones on Ebay.
I ordered that samco hose kit from two places, noone has them in stock
LaureltheQueen
- Spelling Nazi
Well THAWA, that's because it's for an older car and I bet expensive. Did you try any place outside of the US? http://www.forgemotorsport.com/content. ... t=1602SILH
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
93 Sport Sedan, 5mt
LaureltheQueen
- Spelling Nazi
well I sort of have a friend who's dad spends ridiculous amounts of money at a local porsche shop, that carries samco tubing, they're sorta VIPs there. A mutual friend got a couple hundred dollars off of seats there for dropping his name
It's like $75-$100.
I didn't try anyplace out of the US because I don't think samco keeps these in stock. I believe they're special order, so no matter where you order they're going to take a while.
