Can I use a heavier flywheel?
douglas vincent
Post by douglas vincent »
So last year I got a good deal on a new flywheel off Ebay. 100% new but for a newer Forester (I think).
Anyway, its direct bolt on, but if you know your older Legacy flywheels, you know they are kind of "cut" out but this is a casting process, not a milling process. THis means it is about 5-10 lbs lighter than this newer flywheel.
What will this do to my engine? My older flywheel is pretty shot.
Is the flywheel from the forester from a n/a or turbo forester?
If it's from a n/a forester, then you can use it, and everything will be fine.
douglas vincent
No clue.
All measurements are 100% identical. Its just thiicker in the casting where the stock flywheel is dished out.
if it's a n/a style flywheel and the mating surface is the same....I wouldn't see why it wouldn't work.
Post by BAC5.2 »
Heavy flywheels are good for launching. Go for it.
Lots of local high-output cars use stock flywheels.
