I have some engine issues
irishsetter
Post by irishsetter »
I have a 91 ej22t and the only mod I have it the mug. I had some crazy codes poppin up and decided to change out the knock sensor. That fixed it for a while but now I have more crazy codes. 24 Air control, 22 Knock sensor again, 35 Canister purge soleniod valve, 44 Duty soleniod valve(wastegate control). What is wierd is that if the car cools down and sets then after I start it and let it warm up the check light will clear then after normal driving it will reappear with same codes and stay on for the duration of driving. I am stumped and have two month to get her in tip top shape for the subaru challenge coming up. I hope someone has answers.
irishsetter
No ideas anybody?
professor
Post by professor »
check your voltage from your alternator.
a faulty voltage regulator (its in the alternator) will give voltage spikes and set codes galore
I put long leads on a meter and set it on the passenger's seat to see what was what
Post by entirelyturbo »
I'm fortunate to be able to say that I haven't had CEL's in years.
According to Josh's website (*&$^% Haynes don't say anything), the air control valve is basically your rev limiter, it works with fuel cut to prevent 'abnormal engine speed.' I have no idea where that is, but it might need to be checked out.
It sucks donkey balls when you have all these codes, because it's usually one code that's pointing to the culprit, which by upsetting the delicate balance, is pissing off the other sensors that are throwing codes.
The drawbacks of OBDI :(
I'd check your knock sensor connection again too. Make sure there aren't any exposed wires or anything that could be grounding out on the bellhousing or something. I don't have an SS so I have no experience with the wastegate solenoid, but check that too...
Also, just to make it more confusing, moisture under the hood can cause all the sensors to short out, and they will all throw codes. Have you been washing off your engine with a hose, or hit any deep puddles lately (it's been raining cats and dogs here in FL, so that I would understand.)
I might meet you at the Challenge, so get up and running!
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
where does it say the air control valve is the rev limiter?
irishsetter
Cool thanks for the info I think I have my work cut out for me this weekend. I will still make it to the meet and hopefully be running strong by then.
Josh, that's what I gathered it was. It doesn't say it specifically, but I dunno what else it could be.
Quote directly from your site:
Prevents abnormal engine speed using "fuel cut" in relation to engine speed, vehicle speed, and throttle sensor position
That quote is what the "fail safe" operation is of the ECU when the idle air control valve is not working.
Basically, what it's saying is that when the IAC valve is not working, it uses other sensors to help maintain proper engine rpm/idle.
irishsetter
Ok I disconnected all my sensor connections and made sure that they were dry and not burned. I also did a tune up(plugs, wires, air filter, fuel filter) and now the engine check does not clear at all. the car is running smooth now but I still have so sensor issues.
TheSubaruLegacy
Post by TheSubaruLegacy »
Just unplug the damn connector so it'll stop throwin' codes at you (and the dude in the rearview mirror).
Ghetto Sled.
Hooks Hard And Goes Straight.
TheSubaruLegacy
Just kiddin'. Josh's site helped me religiously with ECU codes.
Thanx Josh.
Ghetto Sled.
