power mode/poor torque converter
Saskatchewan Subie
Post by Saskatchewan Subie »
Does anybody know if it's possible to set something up so that you could manually turn the power mode on and off like with a toggle switch or something. The reason I'm asking is because my tranny seems to shift far to early even when I've given it a lot of thottle. It just seems to drive a lot better in power mode.
Actually a lot of the time, the engine and tranny seem to be fighting each other and the end result is very poor acceleration, unless I step on it quick to engage the power mode. I sometimes wonder if my torque converter is about to fail and that's why it seems to struggle because when the weather is cold, the torque converter takes a very long time to lock up.
Anybody have the same problem or can offer me some advice?
93 Legacy Turbo 4AT
tris91ricer
Title Whore
Post by tris91ricer »
I won't make any piercings jokes. :wink:
It could be your TC, or it could be the whole tranny. Instead of worrying about it, why not check out the tranny swap page, and think to the future:
www.surrealmirage.com/subaru/swap/swap.html
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
What you're probably experiencing is simply an aging transmission. Unfortunately, there's not really a solution other then rebuild or replacement.
As for the power mode thing....no not really without screwing other stuff up.
Splinter
Post by Splinter »
Legacy777 wrote:What you're probably experiencing is simply an aging transmission. Unfortunately, there's not really a solution other then rebuild or replacement.
How come it can be done in JDM cars?
tunered
Post by tunered »
i dont think the torq converter will lock up till operating temp is obtained.
ed
