will a 5mt from a 97 legacy sedan work in a 94 SS with an auto? i know ill have to change the ECU, but has anyone tried this or know if it will work?
Thanks in advance
Sam
94 SS and 97 Legacy 5mt will it work?
I doubt the final drive ratio is the same as the SS.
mhrallyteam
You don't have to change the car ECU, there is a pin on the connector that let an auto ecu run with a manual tranny. Its a matter of replacing a ground signal to the pin with a 12v signal.
Then you just remove the auto tranny ecu, which is a different unit.
Other than that it shoud fit if you use the whole drivetrain
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
