But i have a few questions:
does anyone know, or is, running 2.5 heads on their EJ22T block?
If so, are the exhaust ports compatible with a Legacy Turbo manifold? or do we have to use the 2.5L manifolds and customize the exhaust?
Can anyone lead me into the right directions for frame prints? we need a blue print of the frame so we know where to have our wheelbases to start at, along with a pile of more info we need. If someone has some prints or knows where to get a copy for the 93 legacy sport sedan, that would be awesome.
also whats the largest rim to fit on a legacy and clear the struts? we have an extra set of 17"x7" Tenzo's were planning on using, but if they wont fit we might just stay with the stockies.
were also thinking on our own custom exhaust from turbo back, since we havent gotten far enough to remove the shields, does anyone know the size of the inlet on the turbo, along with the exhaust out?
Last of all, with 2.5" heads, STI intercooler, aluminum radioator and a EJ22T what is the max boost that can be run through this?
Thanks guys, this is all i could come up with off the top of my head at the moment, but i have tons more questions in the works
Heres some pics of progress made today:
http://photobucket.com/albums/a289/samcr/
Thanks in advance for any info you can put up
Cheers!
