Was getting worried the last few days. I was starting to get HUGE clouds of smoke following me. The last time this happened, I of course had destroyed pistons. And this time I havent even hit 400 miles, and only 100 on 2 psi of boost.
So I jacked it up and checked it out.
Oil is visibly pooling on the bottom of the driver side valve cover after cleaning it with a paper towel. Ah, easy fix.
Finally had a bonafide valve cover gasket failure
douglas vincent
douglas vincent
