best springs
blakh
best springs
Post by blakh »
hi i have a 93 L FWD sedan and was hoping that maybe some people here have used more then one type of springs on some of their rides, so i could get a comparison between a few brands that i was looking into, or if you just have something to say about them id be glad to hear it.. these were the companies i was looking at:
BG Suspension
Eibach
HR
RSR
TEIN -? if they make ones that fit.
thanks
ej22t
Post by ej22t »
Are you going with the stock shock and just replace the spring?
If you only go with the spring then I will suggest the eibach.
BTW, I do have change the AGX shock with stock spring and it gives very good ride.
Just my opinion.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
i'm a fan of my whitelines, but dont think they make springs for the fwds
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
blakh
Post by blakh »
i will be getting gas-a-just (my mechanic said he could get a some that worked) or AGX shocks/struts. but i still dont know what springs, i tried to find reviews on them but no luck.
LaureltheQueen
Spelling Nazi
Spelling Nazi
I believe that Tristan has a set of near-new GR-2's that he'd love to get off his hands for a fwd
blakh
Post by blakh »
no problems with them?? i have read good and bad things (they go out after a year, some people said they are worse then stock) about the gr-2s so im wasnt sure how good an idea it was to go with them, but i am open to hear your guys opinions since u all have the same kind of car.
JasonGrahn
Post by JasonGrahn »
BG - crap
Eibach - sag
RSR - never rode on 'em.
TEIN - sag AND uncomfortable.
You need new shocks if you're going to upgrade your springs.
-Jason Grahn
blakh
Post by blakh »
i already said i am going to get some kyb shocks i just need to find a good pair of springs.
JasonGrahn
i had KYBs and H&R springs in my legacy for a LONG time, even before i started working here. Awesome ride. Eventually sold the setup to -K-.
-Jason Grahn
Subaru_Nation555
Post by Subaru_Nation555 »
I'm very happy with my setup (H&R springs w/ GR-2s)
rightandtight
Post by rightandtight »
i just installed Koni inserts for an RS with 2000 RS springs and tophats. i've driven it across country but have yet to tune everything. at medium stiff, the struts are strong. i'd recommend the RS springs, the ride quality is pretty much perfect for me--not too stiff or bouncy, just solid.
LaureltheQueen wrote:i'm a fan of my whitelines, but dont think they make springs for the fwds
I had my whitelines on when my car was FWD.
FWD/AWD doesn't really matter too much, as long as you have the correct struts.
sillyp
Post by sillyp »
rightandtight wrote:i just installed Koni inserts for an RS with 2000 RS springs and tophats. i've driven it across country but have yet to tune everything. at medium stiff, the struts are strong. i'd recommend the RS springs, the ride quality is pretty much perfect for me--not too stiff or bouncy, just solid.
i second the RS springs - wrx springs would most likely work well too. You could prolly get some on ebay cheap
92 5mt AWD
F250 duty
12" Johnson
Psychoreo
Post by Psychoreo »
got my wrx struts/springs/tops for $150 (set of 4). but since i'm still not done with my engine swap (electrical), i have no idea how the ride is. i'll let you know once i get it running.
stupid electrical work...
blakh
Post by blakh »
k thanks guys i havent baught my springs yet so if you still have something to say im all ears.
