Quick question about ECU pinout
Post by 1-3-2-4 »
I hope I did not label the wrong cables but the Diagram they show for the ECU Connectors are a head on view right?
I'm hoping so as the Fuel Injector 4 wire matched in colour.
Yeah it's looking directly at the ECU and its connectors. The connector plugs are a mirror image.
1-3-2-4
Post by 1-3-2-4 »
Thanks.
1-3-2-4
Post by 1-3-2-4 »
Well crap I think I labled every Connector wong if you said it's the view of the Conenctor plugged in the ECU and Mirrored.
Natoe
Post by Natoe »
hmm that always sucks, good thing you caught it before you cut anything though...
hey are you "subaruimpreza_power" on nasioc? seems like he said the same thing over there.
1-3-2-4
Post by 1-3-2-4 »
Natoe wrote:hmm that always sucks, good thing you caught it before you cut anything though...
lol Yes Natoe i'm subaruimpreza_power at NASIOC.
I have about 35 or so wires labled.. Maybe this time I will label the wires while they are still pluged in the ECU.
OR.. Subaru could be smart and Put Numbers next to each Slot where the wires go. :x
These two views are oriented the same.
http://www.main.experiencetherave.com:8 ... _page1.jpg
http://www.surrealmirage.com/subaru/ima ... P_3465.JPG
The pinouts are of the ECU terminal....not the connectors themself.
Hey, Josh, would you mind if I took one of your pictures of the ECU connectors and put a piece of it on my ECU pinouts page?
No, that's fine, go ahead.
Cool, thanks... it should help clear up some of the confusion that occasionally arises.
1-3-2-4
Post by 1-3-2-4 »
Legacy777 wrote:These two views are oriented the same.
Ahhh... oh gosh well thats going to take awhile to do that all, still waiting for the carpet to soak up.
Natoe
Post by Natoe »
rather than start a new thread or pester someone with a PM again ill ask it here.
on vrg's ecu pinout, there is a "engine speed output" (not VSS) and on the 1.8ECU it had a "tachometer output" wire, it seems that they should go together... since they are some of the only wires i havent figured out.
thanks
Huh? There's nothing in my diagram called "engine speed output." There's "engine tachometer output." It sounds right...
Natoe
Post by Natoe »
sorry other way around, on yours there is "engine tachometer output" and the only thing on the 1.8 ECU is "engine speed output"... it must be right.
Oh.
Yeah, I think you're right.
suberboy
Post by suberboy »
Josh,
Do you have the rest of the ECU pin out diagrams? I've got the one that VRG so graciously posted but I would like to get the pin outs along with all the voltage/signal references.
Thanks,
noah
Natoe
Post by Natoe »
looking at the diagram for the IAC again... i think i was going by the AT picture. is the AT and the MT IAC valve the same..?
Natoe
Post by Natoe »
edit: jk musta just been my computer, i opened it now
btw josh the 'MAF testing2' page isnt opening for me, just thought you should know that. ive been reading through the IAC and TPS things really carefully and have already caught something i did wrong, thanks so much for hosting all that and how its organized!
the maf2 page works for me. Try clearing your cache and d/l again.
