Perfect Power install diagram?
douglas vincent
Post by douglas vincent »
Picked up a Perfect Power finally,
But I then realized I didnt have a wiring/install diagram.
But I KNOW some of you have installed them, care to share the wiring diagram?
Thanks!!!!!!
Binford
Post by Binford »
douglas vincent
Nothing for a legacy there, already checked.
Unless the legacy is the same as a WRX or RS or what not.
Binford
Post by Binford »
Sorry, didn't look that far. I was already checking out their site in another window when I read your thread.
Doug,
After looking over the developer's manual a little, there doesn't appear to be a "straight forward" way to install it.
The reason I say that is because you can use throttle sensor for the deflection signal (to give the PP an idea of engine load), or the MAF sensor.
My setup may be a little different then yours. I know when I was looking through it, I had some questions on which ignition signal it was as well.
I talked to Sean about it, and he said he could have that all setup when I bought it. I'd try talking to sean or kelley, especially if they've done a 1st gen legacy.
I'd like to see what they recommend to use.
