I got a aftermarket downpipe not sure of the brand but it came off of a STI and it has the 3rd cat delete. I used that and the stock mid pipe off of the legacy ss and a blitz nurspec axel back and it works perfect no modifications needed. Just you need long exhaust hangers so the exhaust wont melt the bumper.
I noticed an increase in power and torque and more turbo noise.
Got a Exhaust
Could we get some pictures?
Is the downpipe a one pice or two?
Is it a 3" or 2.5"?
Is is a bellmouth, divorced wastegate design, or wastegate plate design?
Sorry for all the questions, but this will help narrow down what pipe you have.
Is it a 3" or 2.5"?
1987 Buick Grand National
2003 WRX Sportwagon - ej207/vf30
2004 STi - built motor/gt35r
Exhaust
It is a bellmouth and it is 3" and it is designed for the wrx with the 3rd cat delete. It is one peice. I still have the stock legacy ss midpipe with the cat. And everthing fit perfect except i need longer exhaust hangers to allow the exhaust to hang lower so it wont burn my bumper!!!!
I will try to get a pic up soon.
DOWNPIPE!!!
Its not a Invidia that wouldn't work because it didn't have the flex joint inside of it!! And its not a helix its not a polished peice its just stainless steele. The bellmouth isn't as open at the invidia or helix its like a HKS downpipe with a wider opening!!!
Re: DOWNPIPE!!!
Invidia downpipe dosn't have a flex joint. That is odd that it is like the HKS with a wider opening. Maybee a quick fix to an HKS? Pics would help immensely.Legacyturboguyin253 wrote:Its not a Invidia that wouldn't work because it didn't have the flex joint inside of it!! The bellmouth isn't as open at the invidia or helix its like a HKS downpipe with a wider opening!!!
