Im curious to what can be the cause of high Idling?
happens on first start ups on cold engines.
rpm needle stays at 3K for a few mins.
im curious if an exhaust leak could cause that?
and also the car stalls out every now and then.
its a MAF base car so im thinkin the exhaust leak located by the up-pipe is causin this???
any input is appreciated.
idle problems and stalling
free5ty1e
It's supposed to go up to 1.5k RPM or so to warm itself up, and will work its way down to around 750-800 RPM or so.
How low does your idle settle at once the engine's warmed up?
-Chris
91SS 4EAT stock, 200k mi
mine jumps to 2K upon startup.
if I leave it, don't let the clutch out or nothing, it'll slowly work it's way back down to normal idle once warmup has completed.
I can give the throttle a little blip and it'll settle down to idle speed.
#82 M4 TRSCCA Rallycross
Soul Shinobi
I also get a jumpy needle sometimes when I start the car and the engine is warm. It will bounce around in idle territory between 1k and stall, although coming close it hasn't stalled when doing this.
I don't think I have an exhaust leak, and I'm fairly sure my O2 sensor is working properly. I've tried a few things, but none of them made it go away. I've cleaned the MAF (Mass Air Flow sensor) with Seafoam Deep Creep (a carb cleaner), and also the IAC (Idle Air Control) valve and intake manifold with Deep Creep as well and nothing has really changed.
Anyone have an idea what could cause this?
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
I noticed my tach was 'jumpy' shortly before the car ceased to run. The cause? timing belt jumped thus throwing off the timing.Soul Shinobi wrote:I also get a jumpy needle sometimes when I start the car and the engine is warm.
'11 WRX Limited
'94 TW | R.I.P.
Soul Shinobi
I'm going to replace my plugs and wires soon, we'll see if that makes a difference.
-Nick
douglas vincent
