2.5 RS (Pre-01) Struts on a SS
High PSI
Post by High PSI »
Have the opportunity to pick these up for cheap. I've read the compendium, I know they'll bolt right in, but are they stiffer than my stock turbo shocks? My shocks feel shot so I have to replace them anyway, I'm just wondering if, new for new, these would reap any sort of performance benefit.
Thanks. :-)
rallysam
Post by rallysam »
I don't think it would be worth it. They might be a little stiffer, if only because they're newer, but I'm just saying it's a lot of work for not a huge gain. If you have the money, then pick up some KYB GR2's or KYB AGX. They're not terribly expensive either - probably no more expensive than stock parts if you compare new-vs-new OR used-vs-used.
'00 Impr RS - sold
High PSI
Post by High PSI »
Someone locally was going to sell me a set for $20 picked up. I figure I can change out the struts in 5-6hours, so $20 + a days worth of work for shocks half as old with half the mileage on them seemed worth it. :D
I was going to pick them up today, but I haven't heard from the guy...I'm thinking it may have fallen thorugh. Oh well, maybe it's for the better anyway.
Still keeping an eye out for some used KYB's.
rallysam
Post by rallysam »
Well, I guess if you don't mind spending the 5-6 hours, then I'm sure they'd be better than blown shocks. I mean, any original BCBF shocks are so old now that they are terrible. I just say it's not worth it because I've changed shocks so many times... I don't like how much time it takes and the cursing at rusted bolts and brake fluid spills and dealing with the friggin' spring compressors and then the 4 wheel aligment. So personally, I wouldn't want to do it again unless I was getting a really nice setup from it. But, if that guy does respond and you don't mind it as much, then go for it.
'00 Impr RS - sold
High PSI
Post by High PSI »
Speak of the devil...
The guy JUST E-mailed me back. I'm going to pick them up. Guess next weekend I'll get to enjoy some of the fun you speak of. :P
I should PROBABLY just slap on a set of KYB's, BUT this car handles HORRIBLY right now, and my money is tied up in a million other things....
....Koni's and a new posi unit to get the Camaro prepped for the next auto-x season...
....new built stroker for my eclipse to replace the one I blew up last year....
....finish up that turbo kit on the SC300...
Yeah, tied up and then some. :shock:
To tell ya the truth, maybe I DON'T have 5-6hours to spend. :lol:
