I did a lot of shopping around and I think I got a pretty good deal on most of the stuff…
Metal Master Brake Pads - $77
WRX Wheels - $300 with decent tires
AGX Struts - $ 400 New
Eibach Pro Kit Springs (with WRX Tops) - $180 springs, $50 tops
VDO Boost, Oil Press and Volt Gauges - $130 New
WRX Top Mount IC - $70
VF24 Turbo - $350
EJ20G DOHC Heads, Manifold and Injectors - $400
Helix 3” SS Turbo Back Exhaust (installed a few weeks ago) - $450
So that’s $2280, plus I figure a few hundred more to get it all installed. I’m planning to repaint this summer, but since I do my own paint work that will only be about $400. I bought the car with a bad clutch for $1400 and installed a nearly new WRX clutch/flywheel for $225 So I’ll be in the car a total of around $4600… not to bad I think.
And just so you don’t do think I’m made of money I’ll give ya a little back story. Normally it would take me years to scratch together something like this but I recently switched jobs and after 11 years of taking very little vacation I had quite a bit of time accumulated, the pay out was about $4400. So I figured this was my chance and that I had earned it, Ha Ha Ha.
Yes, I use the lathe/mill quite a bit, just last night I used it to make part of my gauge mounts. It’s a top of the line Smithy 13 x 40.
Gary
And Steve, my IC could kick your ICs a$$ any day
