Cigarette lighter replacement
2 dumb questions:
1) How do I replace the cigaterre lighter ?
2) Can I buy any generic one, or do I need a sub specific ? I am only using it to power my iPod !
Cheers
JF
93 Legacy L Wagon
4WD
5 speed
Too much rust !
Cheers
JF
93 Legacy L Wagon
4WD
5 speed
Too much rust !
Legacy 1993 AWD Wagon
5 speed
5 speed
Very Good Question...
That's a very good question...mine also isn't working and I'd like to get it fixed...if you find out, let me know and I'll do the same.
1991 Legacy L, AWD, 5 MT
Have you removed one, Phil? I just gave a quick look over mine and couldn't figure out how to get it out. Its bezel doesn't seem to be a snap-in-snap-out deal like the dash switches' bezels.
The cigarette lighter? I think I read in the FSM or Haynes that that it is screw-mounted. You have to remove the whole instrument bezel to expose the screws. At that point I gave up and did my projcet a different way
'00 Impr RS - sold
I remember looking at it when I had removed the upper console trim (when I removed the gauge cluster), and I don't remember seeing any obvious mounting hardware.
I guess I'll take a look at the Haynes manual though.
- Title Whore
Yes, its screwed on. Mines been giving me trouble as well -- the sidekick makes a squeal when the charger is put to it, and I believe the cigarette lighter to be the source of its power fluctuations.
Just get in the dash and replace it. A good 90mins with your car, and you've learned something, and replaced a part. I'm the idiot around here -- if I can do this, yall can too.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
So true, well parts of it at least.tris91ricer wrote:Yes, its screwed on. Mines been giving me trouble as well -- the sidekick makes a squeal when the charger is put to it, and I believe the cigarette lighter to be the source of its power fluctuations.
- Title Whore
If you take the kick panel off, (driver's knee - knocker) and reach up and around, the screw (phillips head) should be on the left. I believe there is just one. . .
. . . Feeling. . ..
Yeah, just one.
Will, I'm glad you really do think I'm an idiot. I can't wait to surprise you later.
. . . Feeling. . ..
Yeah, just one.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
Thanks for that, I kind of gave up on figuring out how to replace my now defunct lighter on my old SS after about 5 minutes of messing with ittris91ricer wrote:If you take the kick panel off, (driver's knee - knocker) and reach up and around, the screw (phillips head) should be on the left. I believe there is just one. . .
[size=75]91 Perl White 5MT Legacy Sport Sedan[/size]
