Water Sound under dash - 94 Leg SW 250T
Now and again I hear a noise which sounds like water running down a pipe. Is this normal because I had a new water pump put in about a year ago.
IronMonkeyL255
Make sure you have all the air out of the coolant system.
Mine was making the same noise occasionally for quite a while before I did a REALLY thorough burping of the coolant system.
Rio Red '91 Legacy SS
thehookeup
Project_Legacy
