Moderators: Helpinators , Moderators
2wdlegacyenduro
Posts: 31 Joined: Thu Oct 27, 2005 4:09 pm
Post
by 2wdlegacyenduro » Wed May 03, 2006 11:10 pm
Can anyone help me on this ?
Shifter no longer works with just the selector button on the side, you must depress the the shift lock button to get out of PARK.
Once you do that everything works fine until you go back to park, then you have to again hit that shift lock button.
THANKS IN ADVANCE
Scott
Splinter
Posts: 3058 Joined: Tue Aug 02, 2005 11:12 pm
Post
by Splinter » Wed May 03, 2006 11:22 pm
Do your brakelights work?
Sounds like either the brake switch or the shift solenoid not working
Bosco
Posts: 304 Joined: Wed Dec 03, 2003 12:09 am
Post
by Bosco » Wed May 03, 2006 11:49 pm
You should hear a click when you press the brake pedal while the car is on and in park. Is the click there?
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
