Matching Flywheels and clutches??
NuclearBacon
Post by NuclearBacon »
Im starting a 5mt swap into my 92 touring wagon, and i want to get a lightweight flywheel...and an awesome clutch.
i read the walkthrough in the library (so awesome, with all the pics) so ive heard people putting WRX flywheels in, WRX clutches in... ect ect ect... then i heard that somethign needs to match... either be a legacy flywheel to a legacy clutch... WRX flywheel to a WRX clutch, ect...
what do i have to match? does this matter? any reccomendations? this will be my daily driver, but i LOVE to drive.. so something fun, but functional :)
thanks so much!
Luigi
Brat4by4
Stratified
Post by Brat4by4 »
Since WRX stuff has a larger diameter than our cars, at least the flywheel must be WRX. So WRX flywheel + stock clutch = ok. Stock flywheel + WRX clutch = bad.
If you switch both to WRX (even if its stock stuff) you open yourself up to a lot more possibilities in the future. Plus easier access to replacements if that becomes necessary. (Personally had to chang clutch 3 times so far :evil: )
Just get all WRX stuff or all tlegacy stuff.
NuclearBacon
Ok, so this may be restating what has been said...
but if i go and order an aftermarket lightweight flywheel for a WRX, and get a exedy clutch also for the wrx... i'll be fine with everything still bolting up.. right?
my main concern is to order this stuff, then have it not fit... then i'm sitting there.. loosing a whole week due to the fact that my parts are wrong..
and a larger diameter as Brat4by4 said... that wont matter? like.. wont matter as in.. wont need modifications to anything else to make it fit? (starter motor, ect) just want to make sure i can minimize problems, but add performance to a car that no one really makes anything for...
TOTAL side note... strut tower braces... WHO MAKES THEM FOR A TURBO TOURING WAGON!?!?!? will an impreza fit, sti? legacy? honda? anything!??! i know people have them... and NO ONE says where they're from or what fits...
HELP!!! thanks ;)
Post by BAC5.2 »
WRX stuff fits just fine.
All GC Impreza strut tower braces fit. 93-2001.
NuclearBacon
BAC5.2 wrote:All GC Impreza strut tower braces fit. 93-2001.
wow.. thats awesome. even with the turbo and everything? i might have to order one right now :)
What about the rear??
thanks!
Post by BAC5.2 »
GC 93-01 rear bar fits.
The turbo doesn't effect the strut tower bolt pattern.
douglas vincent
Post by douglas vincent »
Are you swapping in a Tubro tranny or an NA tranny?
If you are swapping in a NA tranny, NOTHING WRX works. Basically....
But! I have a pretty good setup. Forester flywheel (HEAVY), Kennedy unsprung 6 puck disk and 02 RS pressure plate. Has yet to complain and I have TRIED!!!!!
So far its holding up fine for 5000 rpm drag launches giving me 1.9 60' times. Thats is some serious abuse.
NuclearBacon
douglas vincent wrote:If you are swapping in a NA tranny, NOTHING WRX works. Basically....
wait wait wait...
i bought a legacy L wagon (91) that i'm taking the five speed out of..
so its a NA tranny....
..........and im putting that into a turbo touring wagon (92) ...
so i CAN'T use WRX stuff now?
Thank you for all the info.. again, please help me buy the right parts!!!
THANKS!!
206er
Post by 206er »
the pressure plate configuration is differrent.
however exedy makes a lightweight flywheel and a stage 1 clutch for the NA trans. I have the clutch, its treated me well. $160 on ebay from clutchmasters
Post by BAC5.2 »
Clutchmasters isn't Exedy. If you want an awesome clutch, get a hydro-pull-type (which means you need a different tranny, one from a Turbo car.
NuclearBacon
so i found this....
well i found this... its WAY more then i wanted to spend.. but i was curious if theres another out there thats cheaper...
http://www.autopartswarehouse.com/perfo ... andid=1159
but i just thought about it... and this means that it should be for the turbo TRANNY right???
since it says 2.2 turbo.. .. that would mean the only way would be to have ... a turbo transmission... meaning hydro clutch ...so... that does NOT work
moving onwards.....
if i search for a clutch kit for a 2.2 NA car... THAT should work ... right? (wow this is so much more confusing then i thought originally... i was STOKED about getting WRX parts.. now i am sad lol)
This one should work right (the second one for like $187:
http://www.autopartswarehouse.com/perfo ... andid=1341
and if i get this flywheel (top for lightweight) it will work as well...
http://replacement.autopartswarehouse.c ... el&dp=true
Here are some more clutch kits:
http://replacement.autopartswarehouse.c ... it&dp=true
i'm probably going for the top exedy one... that should work with that lightweight flywheel... right??
so after all of that... outloud brainstorming, and research (haha) ive decided that (if it works) i want...
This flywheel (on top, exedy, $396.00):
and this clutch (exedy $200.30):
I'm not purchasing these yet, but soon.... so if anyone has any other ideas, let me know... or just tell me if my plan will work.
thank you AGAIN for all your help!!!!!
Luigi :shock:
douglas vincent
How much power do you plan on making?
Post by BAC5.2 »
If you use that 3 puck clutch, you WILL break your transmission.
I, on the other hand, am pretty interested in just buying that clutch disc... A sprung 3-puck. Awesome.
200 bucks seems about right for an OE clutch kit. Make sure it's Daiken though. If it's not, send it back.
Post by BAC5.2 »
Wow, they have ACT unsprung 4 pucks for 77 bucks free shipping!
Add to cart!
NuclearBacon
douglas vincent wrote:How much power do you plan on making?
No more then 200 hp... ever. So I figured I could use the OEM exidy and be cool... but add the lightweight flywheel, and have awesome.... lightness...
BAC5.2 wrote:If you use that 3 puck clutch, you WILL break your transmission.
I didnt say I was going to use the 3 puck... I said I was going to use that OEM exidy clutch for 200 bucks....
BAC5.2 wrote:Make sure it's Daiken though. If it's not, send it back.
Ok so what is Daikin... is it a measurement... is it a brand... is it a marking... is it a color... is it a way its machined... is it type of clutch... is it a shape...
(head on desk)
It seems I go one step forward and two back on this... lol ahhh!
Post by BAC5.2 »
Daikin is the brand. Exedy is made by Daikin. So if it's Exedy or Daikin, it's an OEM part. They are purple though, with silver pressure plates.
If you use the N/A tranny, get the following:
The LW flywheel you noted, the exedy clutch you noted.
If it were me, I'd have sourced a Turbo tranny, because then you could use the WRX goodies.
NuclearBacon
totally.
thank you so much! that makes me feel better :) well this tranny might not .... last.. and if it doesnt.. i'll look for a turbo tranny.. but then wouldnt i have to switch to a hydro clutch? and get all the parts for that?
cuz thats what the WRX is right? (hydro)
or could i use a turbo tranny.. but the cable parts im getting from my 91 NA donar L Wagon.....
im slowly getting it... i just need more info...
i wish i had the service manuals... i have them for my 87 GL10 and they're awesome....
thanks again!
p.s...just a side note....does anyone know if you can put a regular hood scoop (WRX) in the opening for a turbo legacy hood? just curious :)
Post by BAC5.2 »
You can't use a turbo tranny with cables.
WRX hood scoop doesn't fit in the stock scoop spot. It's much much larger. I have one on my car, and I need to re-do it.
206er
Post by 206er »
BAC5.2 wrote:Clutchmasters isn't Exedy. If you want an awesome clutch, get a hydro-pull-type (which means you need a different tranny, one from a Turbo car.
thats the ebay sellers name I bought it from.
douglas vincent
I really think everyone is underestimating the abuse the NA tranny can take. And spending too much money on the clutch setups as well.
Tonight I pulled 6 consecutive 1.9-1.8 60' times at the drag strip. 4000-5000 rpm launches. Nary a smell, nary a hiccup.
Total cost on my forester flywheel (new), USED 02 pressure plate, 6 puck disk, used throwout bearing was about $200.
scuzzy
Post by scuzzy »
douglas vincent wrote:I really think everyone is underestimating the abuse the NA tranny can take. And spending too much money on the clutch setups as well.
I've never heard of a broken NA 4.111 tranny. I've heard of applications pushing 300-400HP with them, stock NA 4.111 tranny, no breakage.
It makes you wonder, no?
#82 M4 TRSCCA Rallycross
Post by BAC5.2 »
I've heard of lots of broken N/A 4.11 transmissions.
We had an N/A Forester blow his tranny.
The benefit of hydro pull type transmission is clutch pedal feel. Plus, when you get to crazy modding, you have a wider range of options.
Project_Legacy
Post by Project_Legacy »
im running an N/A tranny and it seems to be holding up ok so far. i just have a stage 1 on it though.
im glad someone already pointed out to you that the n/a tranny's and hydro's are different. :-D
00 5MT AWD 2.5 RS - New Project
NuclearBacon
great thread... hope this helps others :)
