Budget BBK interest?
Post by BAC5.2 »
Hey guys,
Would anyone be interested in a 13.8" 4-piston brake kit that would cost under $300 (minus rotors)?
I have a caliper I want to use, and it would require custom brackets. I have no problem designing the brackets, but for them to be reasonably priced, I'd need 4 (or more) other people to go in on them with me.
Pedal feel and brake increase would be almost identical to the STi Brembo 4-pots.
Anyone have an interest?
I might be able to do something similar for the rear too, but I haven't looked into that very much yet. I'm more worried about the fronts.
You'd probably need 17" rims.
Would you guys be interested?
THAWA
Post by THAWA »
How much would rotors be? Are these EVO calipers? Why so large? How much wider? Some more techincal info on the setup would be good, piston sizes, effective diameter, that sort of thing.
Post by BAC5.2 »
Hardy,
I'd like to get the parts before I start giving out information (incase things change). But rest assured, I don't expect blind commitments.
I just want to see if there might be a market for them. I wouldn't really want to make any profit, I would just want to save money by having a small batch of brackets made instead of just having 2 brackets made.
I'm 99% sure it'll all come together, but I want to have the parts and design the bracket before I set anything in stone, you know?
I did the math, and it should be pretty sick.
THAWA
Post by THAWA »
Yeah, I understand. I think you may have better luck on an Impreza forum though. BTW I'm not interested, just trying to get some more info. My front is done at the moment, big and heavy :(.
Post by BAC5.2 »
I'll probably present it to the Impreza guys. It'll work for all Subaru's though, I rekon.
If I present it to the Impreza guys, I am worried about TOO much interest. I only want 4 other people to get in at the moment. If it works really well, and everyone is satisfied, then I'd look into getting more made.
I want to take care of my Legacy Brothers before I bring it to the Impreza guys.
Splinter
Post by Splinter »
I might be interested in a few weeks, depending on how some financial stuff goes.
it'd be about 3 weeks.
Post by BAC5.2 »
I'll probably have all the parts then, so I might be ready to produce then.
Are you going to send us a tranny?
206er
Post by 206er »
I wouldnt be interested, but at $300 you would have no trouble getting rid of several sets.
Post by BAC5.2 »
The price varies greatly depending on where you source your parts. I estimate the brackets to be $200 or so, and the calipers to be about $100. Then you just need rotors. The Caliper price is all about what deal you can find.
greg donovan
Post by greg donovan »
if you could fit them under the 16"gold 98 RS wheels i would be more interested. no way i can afford a set of 17"wheels and tires.
also, if this were hapening in september i would be even more interested.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Phil,
Have you looked at bias and caliper piston volume changes and all that stuff? I'd be curious to see what the numbers are.
Would this be a better balanced set up front/rear than WRX fronts/3.0 rear? I'd be interested if they'd fit under 16's, though I suppose I could buy tires in bulk for the Mazda and Subaru if I went to 17's.
Post by BAC5.2 »
Josh - If I did the fronts and rears, the bias would be perfect. If I just do the fronts, it would be a bit front biased. I need to re-run the numbers, just to make sure I did things right.
Steve - It would be a much better balanced setup than WRX fronts and 3.0 rears. It would also be vented fronts and rears.
I doubt the 13.8" setup will fit under 16" wheels, but when I do it, I'd be happy to try.
scottzg
Post by scottzg »
what vehicle is the caliper from?
IronMonkeyL255
Post by IronMonkeyL255 »
If they do fit under the RS alloys, I may be interested, but have no $$ ATM.
Rio Red '91 Legacy SS
Post by BAC5.2 »
I am going to bet that they won't clear 16" wheels.
Those of you with 17's wouldn't be interested?
Scott - I'm looking at a few options, it depends on what's most readily available.
Splinter
Post by Splinter »
BAC5.2 wrote:Are you going to send us a tranny?
Yea, Ill be able to let you know at about the same time if its gonna be sooner or later
BAC5.2 wrote:Josh - If I did the fronts and rears, the bias would be perfect. If I just do the fronts, it would be a bit front biased. I need to re-run the numbers, just to make sure I did things right.
What are you basing your bias numbers on that they would be "perfect"? Not doubting you, it's just that one thing I have found.....the "sweet spot" for bias may be calculated and what not, but it still boils down to the driver's feel and what he/her is most comfortable with.
Do you mind sharing the numbers with me?
Post by BAC5.2 »
Josh, I'll re-run the numbers and we'll discuss them. I want as much input as I can get, but I don't want to concrete anything until I have a more complete setup (i.e. have the bracket drawn and know how much it will all cost).
I based my "perfect" numbers because they were close to STi Brembo numbers, I consider the STi to have a near perfect pedal feel.
Pedal feel really has little to do with bias.
Run the numbers and we can chat.
scottzg
Post by scottzg »
i dont think the bias has anything whatsoever to do with pedal feel?
Technically no.....however one could argue the point different calipers have different stiffnesses, which will affect pedal feel due to flexing.....and since different calipers can affect the bias....they indirectly affect feel.
