Swapability of driveline
Threshld1
Post by Threshld1 »
So im looking at a new tranny/diff in the coming month or so to fix my failing one. Ive heard issues of swaping wrx trannys/diffs due to spline count differences on the half-shafts. Ive also heard issues about the wider stance (half shaft length).
My car is a 93 SS 5mt with a 3.90 ratio i believe.
So if im looking at a 2000 2.5rs 5mt tranny and lsd diff with drive shaft (<57k on them for a great price), what other parts would i need to make this work? Flyweel/clutch/fork? Is it doable without swaping hubs?
Forgive me if this has been discussed already, i searched and wasnt able to find anything.
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
Yeah, you can use your existing axles.
The one thing you will run into is the clutch type. Your SS currently has a pull style clutch setup. The 2.5rs uses a push style clutch. You will also need the clutch slave cylinder, and probably the partner clutch master cylinder.
