wrx 05' 5-speed on a 90'Legacy wagon
Arturo
Post by Arturo »
will a wrx 05' tranny fit on a 90 Legacy Ls wagon im trying to complete the AWD swap. Somebody :oops: is selling it to me for $700 and i want to know if it fits.
Suby tech on the way
DLC
Post by DLC »
Yeah, it will fit, but you'll need some extra WRX parts, like the flywheel, clutch and pressure plate, among others.
Legacy Central
Arturo
Post by Arturo »
well i already took care of it but i dont know the gearing on that tranny cause i bought a 3.9 diff from a wrx 03
DLC
Post by DLC »
To the best of my knowledge, all Impreza non-STI models have the same final drive gearing.
Legacy Central
tris91ricer
Title Whore
Post by tris91ricer »
With the 1:1 gear reduction!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Post by BAC5.2 »
The WRX has a 3.90 front diff, a 1.1:1 reduction in the center diff housing, and a 3.545 rear diff. You can't use a WRX tranny with a 3.90 rear diff, or you'll blow the diff.
The STI has a 3.90 rear, but the WRX, and I think the Impreza has a 3.545 rear.
Arturo
Post by Arturo »
what about the speed sensor. I think the 05' is electric and the 90' s not. what can i do with it?
mikec
Post by mikec »
Just stick your existing cable in the new tranny. It'll work fine.
Arturo
Post by Arturo »
thanks! now lets get to work
Arturo
what about the shift linkage
Post by Arturo »
can i use a legacy 94- and later shift linkage and if a can what would i need. :shock:
206er
Post by 206er »
you might try and just use the entire wrx shifter setup and just the body bushing from the legacy.
if i was you, I would make entirely solid shift linkage bushings, and the large round bushing get a poly one from energy suspension. take the bushings apart, go to a plastic shop, and see what round stock they have.
or try and use rod ends through the whole shift linkage, if I was to redo mine i would do that or the hard plastic.
Arturo
Post by Arturo »
:shock: dont get it?
Post by BAC5.2 »
You'd need the whole shifter assembly, including the assembly-shifter "knuckle"
