Transfer case - Dual Range 4WD
alpineraven
Post by alpineraven »
Out of interest, is it possible for me to pull out/take off an transfer case from Legacy 4WD gearbox that has Lo Range (Hi/Fulltime 4WD) on it from a buggered (blown teeths in G/B 3rd gear?) dual range gearbox and fit it on end of Single Range AWD gearbox transmission that is on my 1995 Liberty?
Cheers
AP
Owns 1995 Liberty "Rallye" Sedan - NA 5MT AWD EJ22
All_talk
Post by All_talk »
I'm not sure about the EJ dual range gearbox (we dont get them here in the the US :x ), but in the older EA gearboxes the dual range in not a separate "transfer" case, its inside the gear box built into the input shaft.
Gary
Cool pic.....haven't seen the inside of a subie dual range box.
alpineraven
The answer is no, Dual Range EJ Series Gearboxes are simular to EA series. Found out recently after reseaching, and located Dual Range EJ gearbox. Hi & Lo lever is same place on EA series.
Cheers
AP
