The A/C belt seems tight (mechanic installed it when timing belt done) last year.
When we put the A/C on high, or it may be when the A/C has run for a minute, the belt seems loose.
What would caulse the belt to be fine when the A/C starts but then start to wobble and appear loose?
The A/C has never had any work except replacing the pulley two years ago. Is the compressor okay?
A/C is used as my husband works in Palm Springs... usually 117F but a "cool" 99F today.
We wouldn't have noticed this if we weren't inspecting everything minutely after replacing the heater core.
Thank you forum for the post of the test connector causing a blinking check engine light. Ours also caused the radiator fan to start when the key was in on position.
I love our new modene radiator - all metal - better than oem. Nice that a company still is good after 60 years!
A/C belt wobble
A/C belt wobble
1991 2.2L Legacy L 2wd Auto 422k miles - waiting to have head gasket and trannie seal replaced.
RIP 1993 2.2L Legacy L AWD MT Sedan 280K prior abused.
1993 2.2L Legacy L AWD MT Wagon, got at 184k, rebuilding - burnt exhaust valves
Found out the belt is too loose.
Now we can't figure out what socket we used to get the bolt off to tighten the pulley.
