What is the easyest way to take out the gearbox?? is it under the car or the same way as the engine??
Maby someone have som pic??
Johan O R
Need to replace my gearbox
rallysam
Welcome to the board. A lot of questions have already been answered if you search around a bit.
Everybody takes the tranny out by lowering downwards.
There's a write up and photos of a transmission swap on the "www" portion of legacy central:
http://www.legacycentral.org/library/tr ... onvert.htm
'00 Impr RS - sold
It won't fit.
97 = push type clutch. There aren't provisions to bolt the clutch slave cylinder (which you'd need to use the clutch) to the transmission.
05 STi = pull type clutch, AND it will hit the bellhousing of the 97 transmission.
