Which clutch should i use?
adema2626
Post by adema2626 »
Hi, I just bought a 91 Subaru Legacy EJ22T and I’m looking to replace the clutch and i heard that a good clutch to put into them was an OEM WRX clutch and i just wanted to check and see what you guys had to say or if you had any suggestions of what type of clutch I should use. Thanks
206er
Post by 206er »
need more info...
intended power levels you are going to run now/future
intended use of the car
If you use the WRX clutch & pressure plate you will also need a WRX flywheel since the mating surface is larger then the turbo legacy.
adema2626
Post by adema2626 »
Ok, So if i get the WRX F/W and WRX clutch & pressure plate everything should bolt right up to the Legacy tranny correct? Does it matter what year of stuff i get and does it all half to be the same year? Thanks
adema2626 wrote:Ok, So if i get the WRX F/W and WRX clutch & pressure plate everything should bolt right up to the Legacy tranny correct? Does it matter what year of stuff i get and does it all half to be the same year? Thanks
Yes, if you get all WRX stuff, it'll bolt up.
I don't believe they've changed stuff on the WRX, but it'd probably be a good idea to get the clutch & pp for the same year. You may want to just double check with your local subaru dealer or on www.nasioc.com if the flywheel has changed....I don't think it has though.
adema2626
Post by adema2626 »
Hey thanks for the help i really appreciate it.
adema2626
Post by adema2626 »
Humm iv been looking around on nasioc and it seems like i dont need to get a new flywheel i just need to resurface the one in the legacy tranny or am i getting incorrect information. Thanks
Splinter
Post by Splinter »
Im not sure exactly, I know that Exedy has the same part number for their Stage 1 clutch kit for both the WRX and Legacy
Thats what Im running
adema2626
Post by adema2626 »
So you didnt replace your flywheel or anything? If so WOO HOO one less part to buy cause i already bought the exedy clutch kit my self. Thanks
Splinter
Post by Splinter »
No, I was running the stock flywheel
adema2626
Post by adema2626 »
Thanks for the help
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
Post by BAC5.2 »
I'll go ahead and confirm, no WRX flywheel needed. I used to think so, but I investigated for myself.
Lowjack
Re: Which clutch should i use?
Post by Lowjack »
adema2626 wrote:i heard that a good clutch to put into them was an OEM WRX clutch -Aaron
anyone know how much of a gain this is? Obviously the wrx motor has a couple more hp than a 2.2 :lol: but on a stock motor is it really benificial?
1990 Legacy Sedan
I've got a lovely bunch of coconuts....
