Well, looks like i've joined the ranks of the intercooled.
Posted: Sun Aug 06, 2006 5:16 pm
Finally got around to installing the vf34 and wrx intercooler on the car.
It isn't the most beautiful setup... mostly because some older connectors broke when it was close to finished, hence the "gorgeous" brass-T and see-through hose (but when i have some time, i will shorten the hoses and make it look "cleaner").
The car pulls like a monster now, sounds awesome and is begging to be abused.
In fact i've already scared myself with the acceleration, because i still need to upgrade the brakes to something a little better then warped high quality OEM replacements, lol.
So this will be something to enjoy on my own to and from work... otherwise that bov is just too loud to go unnoticed by the wifey when we go on vacation next week! As it is, I'll probably have to explain it and the whine that can now be heard from the turbo and intercooler.
The plan is to recirc the bov but that looks like a bigger headache then i want to deal with now. Apparently there is no recirc adapter fitting for this model bov... oh well, that's what you get when you buy used, without research!
BIG, BIG, BIG thanks to Nico and his pops Carmen!
I wish i could say they just helped a little, but to be honest, they did most of the work, while I helped a little.
If i had tried to do this in my driveway, i think i would have ended up: upset, frustrated, carless, and still working on it a day later. They had all the tools and miscellaneous parts in the garage to make it work, when things didn't go according to plan. Total time of about 6hrs.
sooo...
The list so far:
1993 Subaru Legacy Sport Sedan
18" ADR's with 215/40/18 Kuhmo's
WRX springs and struts
WRX coolant resevoir
WRX intercooler
IHI VF34 turbo
Blitz Dual Drive bov
3" HKS downpipe
3" custom midpipe with high flow cat
Greddy Evo2 exhaust
Turbosmart Dual Stage Boost Controller 10psi/15psi
Autometer A/F, Oil Pressure and Boost gauges in 3 pod A-pillar
Might seem like nothing special to some of you guys with more extreme mods, but when you consider money spent to date:
car = $5000
parts = $2600
installs = $600'ish
it ain't half bad for just over $8k cdn!
ran 15's on stock turbo and no intercooler, and no idea what i was doing on the track (automagic should have been left in 3rd MUCH longer, where it has more pull, with recent experiments 2nd gear gets me to 120kph no problems, lol).
Very curious to see what it'll do now, and again after injectors and tune.
Anyone up for Cayuga on Monday for a run?
Still to do:
brembo cross drilled rotors
wrx hoodscoop
bigger injectors
neetronics tune
revisit suspension
repaint[/img]
sooo...
The list so far:
WRX intercooler
IHI VF34 turbo
3" HKS downpipe
Greddy Evo2 exhaust
car = $5000
parts = $2600
installs = $600'ish
Still to do:
wrx hoodscoop
bigger injectors
neetronics tune
revisit suspension
repaint[/img]
