Car info:
1991 subaru legacy sedan EJ22
Hey guys I have been stumbling around trying to find a thread about how you remove/replace the engine temp sensor on this legacy. I located the sensor but it is in such a tight spot nothing I have will fit in to pop it out so I can replace it. Not to mention it has the computer plug on one side of it preventing me from ust using a regular socket on it.
Can anyone post a pic of the tool I need and brief directions on how I get this guy out so I can replace it? (checked the library and didn't see any write up on it...fooie!)
Removing engine temp sensor
Manarius
Unplug the plug and use a standard socket on it. It may be a tight squeeze so you may need to use a regular wrench.
- quasi-mod-o
