think that a 225/40 18 will fit on my 94 sedan?
i know ill have to roll it.
overall diameter is25.1 inches
i know they will fit in the front but what about the rear...im not lowered at all...yet
225/40/18
what are the offset of the rims?
i have 215/40/18 on mine... but the offset is like 45 or maybe even 38
my rears are starting to rub, and i will need to roll the inner fenders a bit.
http://bbs.legacycentral.org/viewtopic.php?t=27745
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
crawlerdan
- Vendor
bmxkelowna
crawlerdan
- Vendor
dan, did you roll it, or did you have someone do it for you?
i need to do this, i thought that i had 215/40/18, but i actually have 225/40/18's as well.
rear rubs a little...
15's are back on now, until i replace with firmer suspension, and ideally roll rear fenders.
James L
crawlerdan
- Vendor
nope, that's what i'm running. i'll be rolling the rear inner fenders this spring, and though i'll eventually be going with KYB's i may just give a set of stiffer springs a try.
proper tire fitmet is actually 225/35/18
good luck!
good luck!
James L
