Now it is about to get a full eng recondition as the local subaru outfit it has tested it and think it has a stuck or bent Valve in No3 cylinder as comperssion is down a bit.
So it idles like shit, but goes like a wee rocket once your crusing. I have turned up the idle so the body doesnt rock while sitting at the lights
I thought this RPM drop may be because of the low compression in No3 ,
but latley I have noticed while its sitting out of gear idling as I put my foot gently down on the accelerator I hear a quiet clicking sound from under the dash about knee hight of my accelerator foot, and if I hold my foot in the right spot it clicks away like mad like its shorting out, is there a switch of some kind up there and can it affect my RPM??
