Fuel Injector Upgrade
LegacyT
Post by LegacyT »
Anyone know how much HP the stock injectors can handle before they exceed 80% of their duty cycle? I'm aiming at ~300 crank hp, with a TD05. If I need new ones Any suggestions, are SVX ones good for this type of power?
Thanks,
Mark
boostjunkie
Post by boostjunkie »
Hehe, sounds like you're going the route that Adam took with his (I mean my, hehe) turbo legacy . . . it's even the same color!!
Anyways, Adam set up the car with all the parts in my sig, and told me that 1bar was probably the max boost I could run before upgrading the injectors. I believe he had a source for aftermarket injectors, too. You might want to get in touch with him about this.
Not sure how much horsepower this thing's putting out but I was told ~250-260hp.
Jason
LegacyT
Post by LegacyT »
Does your TD05 have the large 16g or small 16g compressor?
15 pounds on either one is is still way more cfm than a stock IHI RHB5, so thats pretty good, actually really good. And your having no lean run problems, you say?
Mark,
boostjunkie
I'm not sure which compressor the turbo's running, but it's off of an STi model. I believe those may have used the smaller compressor wheel, but don't quote me on that.
As for lean-run conditions, I'll be able to let you know more after I get it dynoed and hooked up to a wideband O2 sensor sometime next month.
I haven't been able to detect any knocking whatsoever from the engine, FWIW.
Jason
teesaa
Post by teesaa »
I have been running 1,1 bar boost for over 4 years now and no problems with the injectors.
You're on the right path with the air-fuel meter. If the mixture keeps rich enought on high pressures & workloads, the you have no problems. Remember to get the injectors cleaned every now & then. They do it with ultrasound these days. Costs you about $ 100 for all injectors.
Legacy 200 STW MY92
boostjunkie
teesaa, I am under the assuption that you have a 2.0L turbo engine whereas the US got the 2.2L . . . do you know if the engines have the same size injectors?
I am pretty sure the 2.2t motors got smaller injectors. Someone else can confirm the numbers, but I think the 2.2t motor got like 270cc injectors......I think.....am probably wrong though....
LegacyT
Post by LegacyT »
The 2.2T got the 370cc pink injectors. The N/A's got the 260cc ones.
Mark,
ok.....I knew it was something like that......just forgot the numbers......d'oh
IggDawg
Post by IggDawg »
Will the 420cc WRX injectors fit?
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
Aaron's ej22t
Post by Aaron's ej22t »
Igg, adam @ z1auto told me that wrx 420cc injectors won't fit cause they are top feed, and our injectors are side feed. the older 93-96 wrx injectors will fit and they are 440cc.
our stock injectors are somewhere between 360-380cc.
Legacyt, your goal is the same as mine. i recommend walbro fuel pump and some bigger injectors (not sure which ones yet).
parallel fuel mod and a better fpr would probably help too. :o
92 Legacy Turbo \ 5MT \ Silver
czo79
injectors
Post by czo79 »
I have a 94 jdm wrx ej20 in my legacy turbo and it has top feed 440cc injectors. Does anyone know where I might be able to purchase a new set of 94 wrx 440cc injectors?
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
boostjunkie
Contact Adam at Z1 Performance . . . just search for the company name on this board.
mTk
no title
Post by mTk »
Aaron's ej22t wrote:Igg, adam @ z1auto told me that wrx 420cc injectors won't fit cause they are top feed, and our injectors are side feed.
I have some top feed RS fuel rails that i could use (NO idea if they would fit) and are already set up for parallel... I guess i'll just get injectors and try it out
MK
1992 BC672 AWD 5MT
-K-
Post by -K- »
After thinking about boostjunkie's setup and people on the rsliberty site, I don't think many of us are in need of bigger injectors.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
imprezausa
Post by imprezausa »
I’m looking for any sources for bigger injectors for EJ22T.
Any one knows one? :shock: :shock: :shock:
2000 Impreza WRC:) (Daily)
1991 Legacy Turbo (RallyX)
1994 Legacy Turbo (spare for RallyX)
2000 Legacy Outback (daily wife)
2002 WRX sedan 350-400 hp - Tom
2002 WRX sedan (parts store)
Brat4by4
Stratified
Post by Brat4by4 »
search e-bay for places that are selling JDM used parts from Japan. they usually have access to junkyards or their japanese equivalent. You can get 93-96 Sti injectors or the appropriate Blitzen injectors, both 440 i do believe. Side feed is the key.
mTk
no title
Post by mTk »
http://www.rallispec.com/product-eng_3.htm
"RST-0622 STi 440cc Side-feed Injector (MY97/98 DOHC) $408/set"
Possibly work?
MK
1992 BC672 AWD 5MT
imprezausa
mk750 wrote:http://www.rallispec.com/product-eng_3.htm
Possibly work?
MK
BINGO :D :) :o :shock: :D :) :o :? 8) :lol: :x :roll: :wink:
Thanks,
J
mTk
no title
Post by mTk »
No prob 8)
MK
1992 BC672 AWD 5MT
