LSD final drive ratio '91 Leg.
siouxbe
Location: Lat. 40.02 North/ Long 105.25 West/ Elev. 5356 ft. People's Rep. of Boulder
Post by siouxbe »
I recently purchased a used Rear LSD from Matt Monson out of a '91 Turbo Legacy sedan which I'll clean-up and re-build with new seals and gasket.
Question is will it change the final drive ratio???
I am putting it my BF '91 NA 5 spd. manual Leggy wagon if it all works out OK
Comments???
Previous experience???
and yes, I did a search and I read the sticky :P
1991 Subaru Legacy BJ 2.2L/2.5LSTi Block Hybrid N/A w/ over 250,000 miles! 1992 Yamaha Seca II 2004 Dyna Super Glide My other car is a Go Kart Redhair...Black Leather...My favourite colour schemes. If it's not Scottish...it's Crap!
All_talk
Post by All_talk »
The '91 SS VLSD is a 3.9 ratio. I believe the N/A 5MTs are a 4.11, like oil and water the two DONT mix.
You are going to need a SS/TW (turbo) 5 speed trans... or you may be able to rebuild the rear diff with the VLSD carrier and a set of 4:11 gears, a lot of work and tricky to get set up right. If you wanna keep your 4.11 5MT there are 4.11 LSDs, I think they come from USDM/JDM WRXs.
Gary
DLC
Post by DLC »
The 00-01 2.5 RS and 00-04 Legacy GT have 4.11 VLSD.
Legacy Central
Manarius
Post by Manarius »
N/A 91 4EAT's are 4.11 Final.
