Racing brakes
aspect
Racing brakes
Post by aspect »
Hey guys, I'm looking for racing pads but it seems hard to find anything for the legacy turbo fronts. Hoping for something like a ferodo 3000 or 4003. No grip when cold is not an issue.
Any suggestions?
Thanks!
dirt-covered 91 SS prorally
pat richard roll cage, DMS 50mm, stickers...
SOLD :(
99 impreza RS
ver. 7 sti swap, ver. 6 RA suspension, JDM bodywork, rotated GT28rs
Upgrade to WRX fronts and get whatever you want.
tris91ricer
Title Whore
Post by tris91ricer »
My Brake setup now consists of WRX brakes all the way around, and ebc green pads. I like the bite of the pads. In addition, I also switched to the wagon proportioning valve. This shifts the brake bias to the rear of the car, hence, when you really hit the jew pedal, your ass end is skidding first.
Not a bad brake setup, although, with my current suspension, the weight shift is definitly more noticeable.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Tristan,
You're still probably fine. I've got an additional 10% of rearward shift with the LGT rear brakes compared to you're setup.
What do you have for your suspension setup?
jamal
Vendor
Vendor
Post by jamal »
evolutionmovement wrote:Upgrade to WRX fronts and get whatever you want.
I think it's for his rally car, and that makes it a little harder to use rally tires. RS brakes are the same size, use the same number of pistons, and have more pad choices. Are you allowed to change them?
tris91ricer
Title Whore
josh, my suspension is stock. for now.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Yeah, you should be fine.
IronMonkeyL255
Post by IronMonkeyL255 »
EBC has pretty much every type of their pads for our cars.
For racing, look into their RedStuff (street and race) or Yellowstuff (full race).
Part Numbers!!!!!
RedStuff
front - DP3966C
rear - DP3821C
YellowStuff
front - DP4966R
rear - DP4821R
I know the RedStuff are available from Summit, but I dunno about where to get the YellowStuff.
Porterfield also supposedly has some available (R4 and R4-S) for ours, but I don't have part numbers, since I can't find them on their site. I got quotes from a vendor on Nasioc for some various pads.
Hope that helps some.
Also, if you need to contact other manufacturers, you are looking for pads with a certain d-plate #. This number defines shape, size, and thickness of the pad.
For ours, the numbers are as follows:
front - D563
rear - D471
These also happen to be the same pads as on the '95-'96 2.2l Imprezas.
Rio Red '91 Legacy SS
mattyg41383
Post by mattyg41383 »
I have EBC Green stuff pads on EBC sport rotors (slotted + dimpled) stopping power is great. I'm sure the red or yellow would be even better. so I recommend them
-Matt
1993 Legacy SS - auto
1997 Impreza coupe
1986 XT - 14.5s @ 95mph
1990 Legacy wagon "the Red Dragon" -sold (300K miles and it lives on)
tris91ricer
Title Whore
I've noticed recently on mine that I get a fair amount of shudder (thru the wheel) when braking. I suspect, that its due in part, to my shift of the brake bias, and also that my rear rotors were turned, not replaced.
I would wager that, when shifting the brake bias to the rear (or, owning a wagon) means you can't turn your rear rotors, they must be replaced. Also, the greens make just a tad bit of noise under light braking. Kinda squealeeeeeee
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
scottzg
Post by scottzg »
Legacy777 wrote:Yeah, you should be fine.
stock suspension would want a more rear biased brake set up than something that really hooks up.
FWIW, i have rs front brakes and a wagon prop valve. I tried running wagon rear calipers (which would provide the same balance as stock) with the prop valve and found a little dicey for trail braking,you could feel the rear wandering a bit over bumps. I stuck my stock calipers back on the rear, ill probably swap the wagon calipers on with the sedan valve when i muck with my brakes again, they seem to be burning up front pads faster than usual.
all opinion not based on science or .xls's. ;)
IronMonkeyL255
running my stock brakes with a wagon prop. valve, my pads seem to be wearing much more evenly than before.
When running it in stock trim, I ran through a set of OEM front pads in less than a year, while the rears, installed at the same time, were only worn a little. Just recently, when doing my rear lines and bleeding my calipers, I noticed the front pads weren't worn nearly as bad as I was expecting.
scottzg wrote:stock suspension would want a more rear biased brake set up than something that really hooks up.
How so? You have more weight shift with stock suspension under hard braking, therefore you need to unload the rear brakes a little more to keep them from locking up.
IronMonkeyL255
scottzg wrote:all opinion not based on ... .xls's. ;)
Was that a jab at me for sorting through the information and providing facts I thought relevant?
