Hybrid pre/post facelift?
jnorion
Post by jnorion »
OK, so I'm trying to clear up the details of the front end. I have read lots of threads about it, and haven't gotten my question fully answered.
I want to upgrade my headlights. It seems the easiest and cheapest way to do this is to swap to the post-facelift headlights. But I'm trying to see how much I actually have to swap to do this.
It looks to me like I could swap in the hood, the headlights, and the grille from the facelift model, and leave the corner lights, fenders, and bumper from the old style. I would leave the blinkers down on the bumper so there wouldn't be any issue with those.
Has anyone done this, or does anyone know a reason it wouldn't work?
~Joel
You need to swap the fenders as well....this will require swapping the corner lights.
I still don't know if it would all work though...
bmxkelowna
Post by bmxkelowna »
jnorion
Post by jnorion »
But why do you actually have to change the fenders? Isn't the difference just in the slope of the headlights? If all I want is the lights (not a whole facelift) do I really NEED to do those as well?
~Joel
Manarius
Post by Manarius »
jnorion wrote:But why do you actually have to change the fenders? Isn't the difference just in the slope of the headlights? If all I want is the lights (not a whole facelift) do I really NEED to do those as well?
You need everything. Hood, Fenders, bumper, lights, corners, etc. Plus, you'd need some good wiring skills to wire up the new bulb system. It'd probably be cheaper and easier just to get some EDM lights from a LHD model.
Basically, it's not a feasible process.
jnorion
Post by jnorion »
Wiring doesn't worry me, the basic concept is the same, power/ground etc. Not too hard to splice one connector into another.
~Joel
Bheinen74
Post by Bheinen74 »
just fyi the 92-94 headlights suck too.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
jnorion
Post by jnorion »
But at least they have a decent beam pattern and when they're upgraded they're better than the old ones.
~Joel
jnorion
Post by jnorion »
Bumping an old thread... I came across a picture that suggests mixing and matching the pre/post facelift front ends is easier than we thought.
~Joel
Manarius
Post by Manarius »
No, that car there is all pre-facelift. The fender lamps were there standard on the non USDM cars (that car there looks to be JDM).
jnorion
Post by jnorion »
Definitely LHD... but it looked different to me. Hmm.
~Joel
Those side markers are an easy retrofit also.
