shifting problem in 90 wagon please help!!!!!!!!!!!!!!!!!!!!
Arturo
Post by Arturo »
i have a fwd auto legacy and in january i had a problem, the trany wasn't shifting into 2 or any other gear. A tech told me it was the speed sensor that broke inside and that they have to open it up for service, i went looking for other posibilities and found a 96' fwd trany and all the plugs fitted it went in like if it were the original one but when i got it out of the garage for a test drive it did the same $h@# is not shifting i am going to change the computer because a friend told me it was because the ecu is in limp mode. i want to know if there could be something else that could be causing this shifting problem if anybody has info help because i miss driving in my wagon.
Suby tech on the way
Arturo
what!!!!!
Post by Arturo »
how comes no one has an idea of what could it be please help :(
Arturo
holy crap!!!
Post by Arturo »
hey thanks a lot im going to perform it and i tell you what it did later.
Arturo
pulled the codes
Post by Arturo »
it says 11,12,13,14 and 15 all solenoid codes but it can't be because is a new tranny and the same thing happened with the old tranny do you think it can be the computer
Arturo
What a pain in the a$$
Post by Arturo »
i changed the computer and tadaaaaa nothing changed. some one has an idea.
Have you tried resetting the ECU & TCU?
Pull fuse 14 EGI/TCU for an hour.
Arturo
at sucks
Post by Arturo »
i did but no response
Well then, you either have lots of solenoid issues, or more likely, the wiring harness is bad somewhere.
Test transmission wiring harness from the TCU to the connector in the engine bay for continuity, and then check the transmission harness to the solenoids (this will require dropping the trans pan. Or you can just test the resistance of the solenoid to see if its what it should be.
Other then that, I'm out of ideas.
Arturo
plese scoobie shift
Post by Arturo »
Dont you have some transmission specification guide to check specs for the solenoids.
scuzzy
Re: plese scoobie shift
Post by scuzzy »
Arturo wrote:Dont you have some transmission specification guide to check specs for the solenoids.
No offense man but this isn't rent a mechanic, we can tell you what to look for, but doing the work and getting you every little information is not something we can do.
You can buy the subaru specific mechanics manual from the dealer for about $200 that will tell you exactly what to do, and then some.
Your best bet with the number of problems and codes this one is throwing is to take it to a mechanic.
#82 M4 TRSCCA Rallycross
Arturo
Post by Arturo »
Hey dude relax i understand what your are trying to say about the rent a mechanic bull@#$% but if u were a friend of mine i would do everything posible in my reach to help you so keep your hostile attitude to yourself. If you are not writing anything to help dont even bother writing your stuff in here, anyways gracias cabron
There is probably something in the manuals, however I don't have access to it right now, and I've been sick and traveling.
I will help in whatever way I can, but there are limitations to what myself and others can do.
I would really recommend purchasing a set of factory manuals. They are invaluable when working on your car.
Hopefully this doesn't come across in a bad way or like we don't want to help, because it's not. People have lives and other things going on that consume their time.
