Anyway, I need some advice quickly on my beater 1990 Legacy LS AWD. I got this freaking car only a few days ago and all was well. I decided to drain the ATF fluid and put new fluid back in. It was fine for about 25 miles or so. Then it decided it did not want to shift out of gear. 1st gear to 2nd revs high, then under WOT it'll shift near redline. Then 2nd to 3rd must be near redline too to shift. It absolutely will not go in 4th (D).
If it's in the "Manual" mode, I can drive the car through 1-3 gears. Shifting is not perfect either (a little harsh).
So last night I decided to go ahead and pull the pan and replace the filter too. Doing this I also cleaned the pan really well, installed a new magnet, and a new o-ring on the filter. I got some better synthetic ATF this time around and the same damn thing It is a little *smoother* but it's just wacked still.
Other issues:
1.) Besides the shifting issues, when I go to turn sharply the read end is locking up, not both wheels just which ever wheel inside to the turn is.
2.) When the car is in Park (P), and I turn the ignition off the car lunges forward. Almost like it was loaded up.
3.) If the car is in Manual mode and the trans is in gear, i.e. sitting at a light with it in either 1,2, or 3, and if I release the brake pedal it barely moves, almost like it has the e-brake on (it's not though). Now the same situation but I release the Manual button to regular mode and the car wants to move forward as any other AT trans car would.
4.) I tried the the TCU test to check codes but that procedure doesn't work for me. I also pulled the negative battery cable and mashed the brake pedal to completely drain the electrical system but I still get the same issues. However, I do notice that after turning the engine on that the "power" light will come on for a moment and then immediattely begine to flash 16 times. It does this sequence only once and does not repeat thereafter. Although, there's no 16 code for the TCU that I see. Only a "15" for a shift solenoid. Could this be what's the issue?
5.) Higher than normal idle. About 1k rpm idle. There's a CEL as well so I'm not sure how one affects the other on these cars. Too bad OBD1 is such a PITA
