knock senser
GotSubie
knock senser
Post by GotSubie »
Hey I’m trying to diagnose a fuel cut problem so took off my intake manifold just to check to make sure everything was hooked up ok. Well I was looking at the knock sensor and I noticed the connecter looks a little messed up. So my question is what should I do because Subaru doesn’t sell those connecters separately and I’m no wiring genius.
The connector on the knock sensor side, or the connector on the chassis side?
GotSubie
Post by GotSubie »
the chassis side
Hmm.....not sure what to say about that.
Imprezive
Post by Imprezive »
Cut off both male and female parts of the connector and solder in a new spade connector.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
There is shielding in the stock cable.
Imprezive
Post by Imprezive »
But you are only taking out the connector, shouldnt you be able to bridge the shielding with some other wire?
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
GotSubie
Post by GotSubie »
just to let you guys know. I cut off the ecu side connecter and took it down to ralli tech and the guy there kelly just re pinned it and i sulderd it back on. idk if its gonna fix my boosting problem yet but well see.
