I just picked this gem up for $400 bucks, about 3 weeks ago. It ran like crap when I got it, but have since put the timing belt back where it should be, resealed everything on the front of the engine(Crank/Cam seals/Left cam o-ring/oil pump reseal/wrist pin access plug seals). Also had to repair the end of the crank with some weld in the keyway(pulley, and sprocket were "eating each other") used new sprocket/pulley, and welded a stud in the end of the crank, due to the crank bolt snapping off in the crank from way too much loctite. Well now she runs like a raped-ape, but need to figure out the overheating/high idle concern......oh yeah, did I mention it had about 6-7 vacuum leaks. Fixed now though. Blew a hole in bypass coolant hose the other day too. fixed that too. So I took it on a 150 mile trip today, and the shittiest thing happened, last exit my temp guage started climbing, then went back down.....hmmmm.
well, I don't know, i'll start tomorrow troubleshooting. I plan on doing a intercooling job, more boost, as soon as I figure out the rest. Thanks again for allowing me into this great place.
