Auto seatbelts not working
subytech
Post by subytech »
Does anyone know where the auto seatbelt control module is, nobody at work seems to be able to remember the early 90s, and all they can tell me is that its in the back somewhere? Also anyone know of any common problems with the auto sholder belts? Its getting really annoying to have to latch the sholder belt in every time i get in the car.
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
jamal
Vendor
Vendor
Post by jamal »
The coating on the cable on mine got partially stripped, which caused my seatbelt to get jammed and the cable would come out of the track. I just wound it back to the locked position and unplugged the motor which is at the bottom of the b pillar.
I just duck under it when I get into the car.
IronMonkeyL255
Post by IronMonkeyL255 »
If you end up needing a new module, I have one kicking around that I don't need.
Rio Red '91 Legacy SS
