Notice a weird smell, either antifreez cooking or oil or both when heat is on in my 94 Legacy Turbowagon. No coolant leaks visible on ground, and my only oil leak right now is my oil pan which is rotted half way up and Im changing with a new one this week. Water pump and Timing belt were replaced at 135k miles, and just had to go in a few weeks ago and replace the seals cause they were leaking bad, so while I was in there I replaced the belt again as I have several new ones. Heat is very stifling and temperature gauge is dead center. Any ideas?
93 Legacy SS 105k
94 Touring Wagon 152k
96 SVX Lsi 95k
weird smell when heat is on
94TurboWagon
wallgood358
